themaster1 Posted October 18, 2008 Posted October 18, 2008 What are the formats that DVBViewer supports ecxepted the .srt indeed? It appears i have problem with the .sub Someone enlighten me Quote
IRa Posted October 18, 2008 Posted October 18, 2008 What are the formats that DVBViewer supports ecxepted the .srt indeed? It appears i have problem with the .subSrt is supported (that was actually used before *.TS recording format was implemented in DVBV) but I don't believe that *.sub is support. For example Subtitleworkshop can save subtitles more than 10 different *.sub formats and they all are build in different way. (I don't know it any of those is more "standard "). Quote
Derrick Posted October 18, 2008 Posted October 18, 2008 ..if you use ts_recording there's no need to extract the subtitles. Same with other containers like vob. Quote
