Several suggestions
Art Gerasimov
1. Understanding R and L characters in transponders INI files.
2. Add "Ku-L", "Ku-C" and "C band" buttons to the Scan form.
3. Adding a channel manually, without scanning.
3. Multiple customizable filtering, grouping and sorting options in the channels list.
4. Fast access to favorites in the channels list.
5. Detect and use russian/non-english characters in channel names after scanning.
P.S. As a prof. programmer, I can help to re-write the channels list form, because it isn't usable now, especially after using DVBDream... (w00t)
In any case it is a good software with excellent HD support, therefore I've purchased it!
Edited by Art Gerasimov
3., 3., 4. does already work.
BTW I would have serious problems letting a prof. programmer help who can not count... (w00t):)
3. Is not possible for DVB-S2 Channels in the DVBViewer Pro.
Yes, I've found it. It is a good idea to add corresponding popup menu items (w00t)
Do you mean section of "Sort by by channel name" or "Sort by by category"? If I want to sort by channel type (radio/tv), channel name at the same time? Is it possible?
