Johny01 Posted October 20, 2008 Posted October 20, 2008 I like to know if it's posible to do streaming with DVBViewer at internet. I forget do streaming at my network, but at internet I haven't forget. Thanks and sorry my english. Quote
Moses Posted October 20, 2008 Posted October 20, 2008 just install the "Web intervace 1.5" (from the setup => "Modify DVBViewer" Link in startmenue, or download it from the member area) and VLC ( http://download.videolan.org/pub/videolan/....8.6i-win32.exe ) on your PC. Then start the httpserver.exe in DVBViewer folder. If everything (Router and/or Firewall) is setup correctly, you should now be able to access your PC via www and see the EPG for the currently tuned channel (of course DVBViewer should be running). If you click on an EPG entry, you'll see some buttons on the lower right, one looks like a play-button, if you click that one, the steraming pop-up will open up and you can configure & start streaming. Of course you should configure it according to the bandwidth of your internet connection. Quote
