Latest Drivers = No Hardware Detected
Milly
Anyone else experiencing this? also a problem with the technisat version...
On their website there is a clear devices.bat utility to sort for their version doesn't work for pro??
Had to roll back drivers
Anyone any clues... don't have any info on this matter but am sure it can't be that hard to replicate...
you did a manual hardware search in the DVBViewer hardware options?
yeah the skystar shows up and you can select it but when you go to channels it says no hardware available..
as i said i've reinstalled original drivers which is a bit of a pain as windows decides it can choose the best drivers for you,
so i am loathe to install new drivers to show config.
http://www.technisat.com/index5954.html?na...;produktID=1889
if you view this page you can see that technisat site explaining the problem, the clear devices app doesn't work for me!
and you need the latetest drivers because...?
When i change channels from itv hd to bbc hd the image is distorted you have to change to a sd channel to get image back, ta very much...
that's a video codec issue not a driver issue. A driver issue would be no tuning at all or similar...
tried coreavc and powerdvd and it does it with both so are you sure? anyway that is digressing somewhat from the issue...
Software doesn't work with latest bda drivers...
