Findus Posted October 24, 2008 Posted October 24, 2008 Does anybody know how do I get the resolution of the current TV program through the COM interface? (1080i, 720p, ...) Kind regards Findus Quote
Tjod Posted October 24, 2008 Posted October 24, 2008 As far as i know it is not possible to get the informations from the DVB Source via COM interface. Thy are only displayed in the DVB Source, statusbar and in the OSD Info. Quote
Findus Posted October 24, 2008 Author Posted October 24, 2008 Hi Tjod, Thanks for the answer, nevertheless I am not sure whether you are right. In the application "TouchViewer" (this is an external COM application) this information is shown. eg. 720p or Full HD. see: http://www.DVBViewer.info/forum/index.php?showtopic=28220 eg. if you switch the channel from ZDF to ASTRA HD you see the FULL HD Logo. Maybe Lars know. Kind regards Findus Quote
Findus Posted October 30, 2008 Author Posted October 30, 2008 Hallo Lars, kannst du vielleicht kurz was dazu sagen wie man an diese Info ran kommt? Wie ich geschrieben habe, scheint es TouchViewer irgendwie hin zu bekommen. Danke & Gruss Findus Quote
Tjod Posted October 30, 2008 Posted October 30, 2008 I do not know what tomekcp use. But this only will work in future Versions Quote
Findus Posted October 30, 2008 Author Posted October 30, 2008 Hi Tjod, Thanks! Great news. Hope that this is not too far away Regards Findus Quote
