pateras Posted October 26, 2008 Posted October 26, 2008 Dear to all, I have buy yesterday new skystar hd2 pc card with power slot for diseqc motors. I'm using invacom single lnb with stab hh-90 diseqc motor. When i try to make scan channels from any satellites with DVBViewer 3.9.4.0 i have signal only on some transponders. But when i make scan with transedit 3.2.5.0 have signal normally on all frequencies. I use skystar hd2 with latest technisat driver on windows xp sp3. I don't understand what the problem is. Same satellite configuration with DVBViewer work very well with skystar hd . Any help? Thanks and Best Regards Quote
pateras Posted October 26, 2008 Author Posted October 26, 2008 You can find my support file below Thanks support.zip Quote
