marioqm Posted October 31, 2008 Posted October 31, 2008 (edited) Hello, I'm using DVBServer in one PC that has two tunners, DVB-T and DVB-S. The problem is that when I configure the client (using unicast) I can select ONLY one kind of tuner, Satellite or Terrestial, then I can't switch from a sat channel to a tdt channel normally, I have to reconfigure the kind of tuner in the options of unicast. Are there one manner to configure unicast to receive two kind of tunners at the same time (Sat & TDT) ? Thanks Edited October 31, 2008 by marioqm Quote
Tjod Posted October 31, 2008 Posted October 31, 2008 You need two Unicast devices. http://www.DVBViewer.info/forum/index.php?showtopic=30297 Quote
factor Posted October 31, 2008 Posted October 31, 2008 Yes ,you must open usermode.ini in DVBViewer(client) folder and set [Card] unicast=2 restart DVBViewer you can see too unicast device also you can set one for dvb-t and the other for Dvb-S Factor Quote
marioqm Posted October 31, 2008 Author Posted October 31, 2008 Perfect, it works! Thanks Tjod & factor, Quote
