Problem with channel lists update
ii141c
Excuse me for my question but I have a new channel list for DVBViewer, but i delete the old channels.dat and put this new one with this name (channels.dat) in c:\program files\DVBViewer (when I have the exe file) and the channel lists does not change and it is the original one (the one that i scan the first time and the one that, teorically, I have delete ).
What is the problem?
Thank you.
The channellist is sotred in the configuration folder. Open DVBViewer, select Help->configuration folder and it should open up the configuration folder for you. Now close DVBViewer and edit the files. :)
