TNT HD (France) wrong aspect ratio (H.264)
Nico13
Hello,
While decoding HD TNT (H.264) channels, the display is 4/3 and the aspect ratio is set to "Auto"
For others channels I have no problem.
In the Options / DirectX menu, I tried to change the value for Video Codec H.264, using Mainconcept , CoreAVC, or Cyberlink, and the result is the same.
I tried FfdShow decoder also, but it crashes with MS VB runtime error.
Somebody can help me?
thanks,
nicolas
Edited by Nico13
Hello,
thanks,
nicolas
Looks to be solved using DVB Filter 3.2.2 :blink:
Nicolas.
Hello,
I read somewhere that for hd channels you had to use the ratio named "none" (aucun).
It works on my PC for all HD channels, on the other hand, I have to set the ratio to predefined on sd channels.
From the keyboard, in full screen, you can cycle through the ratios by the P key.
This issue was solved using DVBViewer Filter 3.2.2, no problems with french DVB-T HD channels :blink:
