Linux DVBServer
CX23882-19
Is there any way to stream from a Linux-based PC (currently running Mandriva 2007) to DVBViewer? I'm currently running DVBServer on a Windows XP PC and it works great, but it means I need to leave my XP PC running for the DVB streaming along with my 24/7 CCTV system running ZoneMinder on Linux which is a waste of power.
So it seems I have two choices:
- Keep Windows PC 24/7 and find replacement (and expensive) CCTV capture app for Windows
- Keep Linux 24/7 and find replacement DVB server
So, is it possible? With DVBServer everything works so well (channel changes, multiple user management etc.).
Is there any way to stream from a Linux-based PC to DVBViewer?
Not really, the DVBServer interface is not documented. And there are plans to cage this in some versions complete.
If you are able to generate DVB-IPTV you will be able to watch tis in the DVBViewer. But channel changing will be a problem.
