banditnew Posted November 9, 2008 Posted November 9, 2008 where can i get it. i can't find member section. is it name change or what? is netstream plugin same with dvbserver ? and i want connect 2 pc over lan and first pc and installed ss2 and second pc control for first pc.not streaming and not for vlc.i want control DVBViewer with DVBViewer.is there any guide for this type connection (english). sorry my language not good for you i know thanks Quote
Moses Posted November 9, 2008 Posted November 9, 2008 netstream plugin and dvbserver is not the same. DVBServer is part of the normal DVBViewer installation, just run DVBServer.exe instead of DVBViewer.exe. You don't need the netstream plugin for what you want to do. Just run & configure DVBServer.exe on your server (where the ss2 is installed) and run DVBViewer.exe on your clients. You need to scan and copy a channels.dat from your server to the clients and you need to configure in options->hardware on the clients the unicast device to match your server's settings. Quote
