No Low Sampling Rate Audio With TSPlayer
Derrick
An experimental mp3_audio_track with 64kbps/24khz can't be played with tsplayer. DVBViewer-pro and other players like winamp, vcl play ok.
General
Complete name					: G:\24_ output.mp3
Format						   : MPEG Audio
File size						: 2.28 MiB
Duration						 : 4mn 58s
Overall bit rate				 : 64.0 Kbps
Audio
Format						   : MPEG Audio
Format version				   : Version 2
Format profile				   : Layer 3
Duration						 : 4mn 58s
Bit rate mode					: Constant
Bit rate						 : 64.0 Kbps
Channel(s)					   : 2 channels
Sampling rate					: 24.0 KHz
Resolution					   : 16 bits
Confirmed.
TSPlayer and the DVBViewer Filter only accept Version 1 Layer 3. Low samplerates require Version 2 Layer 3 (16/ 22.05/ 24 khz) or Version 2.5 Layer 3 (8/ 11.025/ 12 khz). If playing such MP3s with the DVBViewer Filter fails, DVBViewer automatically delegates it to the DirectShow GraphBuilder as fallback.
