Recording problem
Neo Tsui
Dear sir/madam,
I'm using V3.9.4.101 (beta).
When I use the "manual recording" function,
a ) it sometimes records with wrong filename, i.e. wrong programme name (date, time, channel are correct)
b ) for a particular channel (Network ID:32767, Video PID:191), I can't start the recording (seems that the filename cannot be created).
c ) after (b ) appears, the DVBViewer becomes abnormal, even though I restarted it. After I wait for several minutes, the DVBViewer can be started.
Attached pls find the file, support.zip
Thx.
Rgds,
Neo~~~
