damjang Posted January 9, 2004 Posted January 9, 2004 It is possible to turn SS2 off or/maybe turn off the lnb power when close DVBViewer? damjang Quote
Guest Oliver Posted January 9, 2004 Posted January 9, 2004 That happens automatically (full version only). Bye, Oliver Quote
damjang Posted January 9, 2004 Author Posted January 9, 2004 I try some of the last versions and don't. On the antena cable is always 12-17V. lp damjang Quote
Gioxy Posted January 9, 2004 Posted January 9, 2004 Have you tried with this? At least it reset my DiSEqC switch when are stuck... Cheers Gioxy Quote
Guest Oliver Posted January 9, 2004 Posted January 9, 2004 @Damjang: Did it ever function with any version? Bye, Oliver Quote
damjang Posted January 9, 2004 Author Posted January 9, 2004 Yes, the FreeLNB.exe do the work. I retry DVBViewer with "Remember last data channel" not selected and this don't work. Regards damjang Quote
damjang Posted January 9, 2004 Author Posted January 9, 2004 @Damjang: Did it ever function with any version? Bye, Oliver I don't know, in the last few version no, but only one time it did, but I don't know if it was so, because it happen when DVBViewer freeze ... damjang Quote
Guest Oliver Posted January 9, 2004 Posted January 9, 2004 I've just tested it with B2Status from the SDK and the LNB power was switched off. Griga did a "hardware" test and his LNB was switched off, too. What does B2Status say about your card? Bye, Oliver Quote
damjang Posted January 12, 2004 Author Posted January 12, 2004 I've just tested it with B2Status from the SDK and the LNB power was switched off. Griga did a "hardware" test and his LNB was switched off, too. What does B2Status say about your card? Bye, Oliver Where I can find B2Sattus? (or SDK). In the members area I find only plugin SDK... damjang Quote
Guest Oliver Posted January 12, 2004 Posted January 12, 2004 I can't remember, therefore I attach it. You must run it in a DOS box in the following way: b2status -a eth1 Bye, Oliver Quote
damjang Posted January 12, 2004 Author Posted January 12, 2004 Ok, I test it and here are the results (attached). The first is after exit DVBViewer and the second after run FreeLNB. The diference is in Diseqc status... damjang b2status.zip Quote
