DVB-T mpeg4 and asus P7131H hybrid
fernando silva
hello !
First let me say that i love DVBViewer, it works fine with my skystar 2.
Last weekend i buy an asus P7131h Hybird, witch is dvb-t.
the asus have BDA drivers, and i try it on windows xp, the software that came with it (power cinema) works great.
On DVBViewer (channel scan) tunner dont appear.
Another question, terrestrial europe have portuguese frequencies ?
tonight i will format my pc and try vista x86 with coreAVC and only with bda asus drivers
thanks
fernando
Edited by fernando silva
Dunno. Maybe there is a slight frequency offset, like in France. You can try to find it out by using the scanner and transponderlist editor TransEdit from the members area.
Select Terrestrial (EUR) on the left side of the TransEdit main window, then change the frequencies on the right side and scan them. Maybe increasing or decreasing the frequencies by 0.1 or 0.2 MHz does the trick... but before trying that blindly I would search the web for terrestrial Portuguese frequencies.
