No OSD/subtitle
Neo Tsui
Dear sir/madam,
I'm using
- DVBViewer Pro V3.9.4.101 (beta)
- WinXP SP3.
- ATI Radeon HD2400 (CCC 8.11)
It's found that,
(1) if I use "ArcSoft Video Decoder" as H.264 Video Decoder in DirectX option, no OSD or subtitle will be displayed. Also, if I press "Mute" or "Record", it won't display the "Mute" or "Record" icon on the screen.
(2) if I change to use "CyberLink H.264/AVC Decoder (PDVD8), everything becomes normal.
Would you pls help to solve my problem ?
PS : Attached pls find support.zip
Thx.
Rgds,
Neo~~~
