Optimum HD settings
mazza132
All,
Is anyone able to advise what the optimum HD settings should be? Sorry, if this has already been discussed elsewhere.
I am trying to get the smoothest picture on the following HD channels: ITV HD, BBC HD, Sky Sport 1-3 HD, Eurosport HD.
I find the Sky sports channel initially have a green screen for a few seconds, whilst Eurosport is very choppy.
I have left all settings as default during the DVBViewer install.
Thanks
This will depend on your video card, operating system, screen etc. etc. etc.
There is no one "best" answer; just the answer that is best for your equipment.
Thanks - FYI using the codecs from the powerDVD trial version seems to be the best
  • 1 year later...
just out of interest, how are you getting sky ports? [removed] i can get everything apart from sky sports and movies.
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
http://www.DVBViewer.tv/forum/index.php?app=forums&module=extras&section=boardrules
Edited by Tjod
All,
Thanks
what hardware cards/cam are you using??
