Bigus Posted December 1, 2008 Posted December 1, 2008 Hi A couple of questions regarding channel changing/programme info.. 1) When you're viewing a TV channel you can use the up/down arrows to change to the previous/next channels - is there a way to limit that to just those channels in your favourites list? I've tailored my favourites list to include all the channels I'm ever likely to want to watch, so it would be nice to ignore all the others including radio stations. 2) When you switch channel you get a nice big graphical overlay at the bottom with the programme information (see left hand side of image below). However if I want to see that information while watching a channel, all I seem to be able to get up is the smaller bar as shown in the right of the image below which doesn't look very good and the text is very small. Is there a way to call up the nice big graphical overlay (ie: what key do I press)? Thanks Quote
Tjod Posted December 1, 2008 Posted December 1, 2008 1) Take a look in the Tweaks, you have to add UseFav 1 in the setup.xml. You find the right setup.xml in the DVBViewer > About > Configuration Folder. Than close the DVBViewer and add: <section name="Input"> <entry name="UseFav">1</entry> 2) OSD-OK [Enter] Quote
Bigus Posted December 1, 2008 Author Posted December 1, 2008 1) Take a look in the Tweaks, you have to add UseFav 1 in the setup.xml.You find the right setup.xml in the DVBViewer > About > Configuration Folder. Than close the DVBViewer and add: 2) OSD-OK [Enter] Awesome, thanks for the reply :-) I'll have a browse at the Tweaks section tonight as well. Regards Bigus Quote
Bigus Posted December 1, 2008 Author Posted December 1, 2008 Is it possible to get the OSD timeline to only show my favourite channels as well? Quote
Tjod Posted December 1, 2008 Posted December 1, 2008 On the OSD-Timlin OSD-Blue [F8] or Menu > Show Favourites. Quote
Bigus Posted December 1, 2008 Author Posted December 1, 2008 Fantastico. I like this software :-) Thanks Tjod Quote
