clumpco Posted December 3, 2008 Posted December 3, 2008 Hi, I have a Geniatec Sat card with Connexant BDA driver 4.0.107.0 Running on an Asus P5B with a GeForce 9600GT driver 804.8 I have recently changed from a 7600GS to the 9600GT, ever since I have been having problems with HD. I used to use Cyberlink h264 decoder, but the 9600GT install broke this, so I have been trying CoreAVC and Elecard. Firstly BBC HD appears squashed to 4:3 and I have to stretch it. Secondly, and far worse, DVBViewer shuts down after about 30 minutes while on BBC HD, this always seems to happen when the recorded file or timeshift buffer reaches 3.7 GB. There is plenty of room on my hard drive (200 GB free). I do not know if this happens on normal channels, I am leacing it on overnight to see and will let you know. Before the graphics card change the system was very stable. Should I roll back to an earlier driver for the graphics card? Thanks in advance support.zip Quote
clumpco Posted December 3, 2008 Author Posted December 3, 2008 EXTRA - While watching SD programmes it does not seem to close down, I have a 9GB record buffer after 6 hours viewing Quote
