Skaarup Posted December 5, 2008 Posted December 5, 2008 Hello As I understand it, there are 2 forms of IPTV: One that is commonly used in fibre networks (Multicast), which DVBViewer supports. And then there is the type that, among others, the danish provider StremTV: www.streamtv.dk is using. TV stations provided via StreamTV.dk can be viewed in VLC Player. Is there a way to make streamtv streams work inside DVBViewer so that the streams can be watched and tuned as channels in the same way as DVB-T/S/C channels? Regards Claus Quote
Moses Posted December 5, 2008 Posted December 5, 2008 most probably not... you could try to play the stream via "open url" (or similar) from the file menue and see if DVBViewer can play back the stream. Then it's possible to add a ".murl" file for that stream somewhere and you can call it from the OSD Menu. But that's as close to a real tv station as you can get for such streams at the moment... Quote
