mitch26 Posted December 7, 2008 Posted December 7, 2008 Hello I have been able to use DVBViewer to watch HD TV channels in DVB S2 mode in the past (Prosieben, Astra HD Demo, etc...) but now I can't. I still have the same Technotrrend S2 3200 tuner with CI module which works perfectly in DVB S mode. The strange thing is that the original software TT media center provided with the tuner, still works in DVB S2 mode. My direct X settings are on overlay mixer renderer and Power DVD 7 for H 264 decoder. Although I can not see any HD picture, the small display at the bottom of the DVBViewer screen shows the name of the channel that I want to watch, and its characteristics i.e stereo 2.0 16:9 1920X1088 25 fps 192 kbps 48,0 khz. Thanks for your help ! Quote
stuboy Posted December 10, 2008 Posted December 10, 2008 HelloI have been able to use DVBViewer to watch HD TV channels in DVB S2 mode in the past (Prosieben, Astra HD Demo, etc...) but now I can't. I still have the same Technotrrend S2 3200 tuner with CI module which works perfectly in DVB S mode. The strange thing is that the original software TT media center provided with the tuner, still works in DVB S2 mode. My direct X settings are on overlay mixer renderer and Power DVD 7 for H 264 decoder. Although I can not see any HD picture, the small display at the bottom of the DVBViewer screen shows the name of the channel that I want to watch, and its characteristics i.e stereo 2.0 16:9 1920X1088 25 fps 192 kbps 48,0 khz. Thanks for your help ! I would guess in your channel editior the video type is set to mpeg2 not H264 Cheers Stuart Quote
mitch26 Posted December 13, 2008 Author Posted December 13, 2008 I would guess in your channel editior the video type is set to mpeg2 not H264Cheers Stuart Thanks for your help, it was set to H264 but the problem was the Codec : I used the Power dvd 7 codec but since I started using the Power DVD 8 H 264 Codec pictures started appearing, the sound vanished after one minute or so but after choosing also Power DVD 8 for audio Codec, the sound has stabilised. Quote
