AFN Z-Rock and AFN
remlap
On the Pentagon Channel at 13e are two radio stations as sub audio
11096 H 28000 3/4
AFN Z-Rock
AFN Uninterruptable Voice
How do I add them separate radio stations, if I try it will automatically make it Pentagon Channel.
Cheers
Difficult. Export it as INI file, do a lot of tweaking, import it again... no, too complicated. It's really hard to achieve something like this in DVBViewer Pro.
The easiest way: Import the attached INI file in the DVBViewer Pro channel editor. I did the following in DVBViewer GE (that makes it a bit easier):
- Move the audio tracks to a new category folder named Pentagon Radio in a Hot Bird 13.0°E root folder
- Open the channel properties
- With both entries: Set the Video PID to 0 (in order to make it a radio station and let DVBViewer GE reset a Video Service flag) and the Service ID to 0 (in order to prevent the channel auto update function from adding the Video PID again. It disables the EPG for this channel, however)
- Export the Pentagon Radio category as INI file
It may be necessary to adjust DiSEqC and the Channel Group according to your needs. Good luck...
Pentagon_Radio.ini
