DLNA support
MomoBrut
It will be nice to have the possibility to stream DVBViewer recordings directly with DLNA support to all TVs with DLNA support connected to intranet.
  • 9 months later...
Could pls confirm for me that is possible to receive stream from the Recordingservice on Panasonic TV with DLNA support (in manual is mentioned DLNA support but not UPnP). If yes, is there any possibility to switch channels from the TV etc.?
Has somebody tested it practically? Thanks for reply.
  • 5 months later...
I would also like to know if the Panasonic is able to pick this up? I know the tv supports DLNA but I am unable to find out if it supports UPnP?
I have been trying to use the DVB Service 1.5.0.31 (beta) - (assume this is the recording service) by activating the UPnP server but the tv is not picking anything up, I dont know what I am doing wrong.
Can I get some help on UPnP.
192.168.2.103 [PC] - Ports 7522, 8889 open on router, both TCP and UDP (only TCP required?)
192.168.2.104 [Panasonic TXLV10B TV]
DVB Service 1.5.0.31 (beta) > Web/UPNP tab.
Webserver enabled, auto port 80
Streamserver 7522
UPnP AV Server enabled: 192.168.2.103 port 8889
debug: off
alternative id method: off
popcorn support: off
thank you in advance.
blackbooks
Try Version 1.5.0.95 Beta test related to UPnP/DLAN there where huge improvements thins version 1.5.0.31.
http://www.DVBViewer.info/forum/index.php?...st&p=270725
But from the informations in a germen Topic Panasonic did not work.
http://www.DVBViewer.info/forum/index.php?...mp;hl=Panasonic
Thankyou for the quick reply.
I have now tried version 1.5.0.95 but with same result, no server found.
Do my settings above appear ok?
New version "do not use ip's" (Web server & UPnP AV server) - leave blank or 192.168.2.103 ?
thank you.
blackbooks.
leave blank
Do I have to have DVBViewer running or can I just have the recording service running on its own?
only the recording service. Just make sure the firewall is configured correctly to give the rec service access to the LOCAL network.
