DVB-T Australia No channel 10
rison
Hi guys,
I have just switched to DVBViewer and am loving it, But i have not been able to get any of the Channel 10's. I have the DigitalNow PCI-E card and using the DNT Live! software i can get receive channel 10 fine. It's only in DVBViewer i am unable to get it. I am located in Gosford, I pick up all the other Sydney channels ( 7, 9, sbs) as well as the regional channels ( NBN, Prime) fine i just can't get any channel 10.
I have attached the support.zip any help would be greatly appreciated, I want to keep using DVBViewer but if i can't get channel 10 i might have to switch back.
Thanks, Matt
You've written four (!) times that you can't get them, but what do you mean by "can't get"? What did you try? Not found when scanning? Found, but they don't play? A detailed description of your problem is required... always remember that the supporters are not sitting in front of your PC!
After hours of messing around i found the problem.
A heads up for everyone else there is a error in the Australia.ini file.
number 47 looks like
47=788500,7
channel 10 for my area is 788600 so i just changed 47 to look like
47=788600,7
saved the file then re scanned
I can get all the channel 10 channels now.
Matt
