Guest hackbart Posted January 11, 2004 Posted January 11, 2004 As you maybe already read inside the german forum part, i've rewritten the favourite engine. This allows you now more favourite channels and you are able to create subfolders similar like the internet explore does. At the current state its even possible to drag'n drop entries from the channellist. At the moment i have only one design problem with the new list: I would like to add the ability to store also channel icons (like those available at http://www.satlogo.com/) inside the favourite menu. Unluckily i have no idea how to present them in the menubar (especially the size, since a couple of logos doe not look nice with 16x16 pixels). Christian Quote
Gioxy Posted January 12, 2004 Posted January 12, 2004 Hello Christian, here was the first graphical suggestion... Quote
Gioxy Posted January 12, 2004 Posted January 12, 2004 ..and this is a second... ...this was also good for a stand-alone Favourit windows... For the icon dimension, I think that the best was if user can choose himself... Cheers Gioxy Quote
