LME DVBS USB
spv4u
Hi
Just bought a couple of these and wondered if anyone has managed to get them working?
The chipset inside is LME2510 comes with a BDA driver and DVBViewer sees the hardware but will not display the video.
A Channel scan actually works fine and finds all the FTA channels so it almost works.
The driver CD also comes with a module for ProgDVB which I have attcahed as this might give the cules as to why this hardware doesn't quite work
Any help would be great, currently running RC1 of latest beta and same result in previous full release
Regards
Mark
LMEDVBS.rar
Edited by spv4u
This controller has a PID filter built-in. So maybe it is not fully BDA compliant and cannot deliver the whole TransportStream. This would also explain why there is a separate ProgDVB device instead of using the conventional BDA module.
If a channel scan is working, the PIDs are known. Try uncheck "Open whole Transponder" (options -> hardware)
I have just tried that with no luck. Any other suggestions?
OK quick update Cinch seams to have found the problem.
When I open ProgDVB and view say ITV1 and then close ProgDVB.
Then open DVBViewer I am able to watch ITV1 fine but not any of the BBC channels as Im guessing these are on another PID
Is there anyway DVBViewer can pass this information like ProgDVB does?
Mark
ITV and BBC are on different transponders. You don't have a correct channel list. Make a fresh scan but before post a support.zip ;)
