Secondary audio track missing
mancio
I'm trying to record a ts stream with two audio tracks. When I take a look to the recording statistics while recording I see 5 PIDS: PAT, Video stream, 2 Audio strems and the PMT. When I play the TS file with, for example, tsplayer, the secondary audi stream is missing. Looking to the streams by PID there are the same streams except the secondary Audio.
The same thing happens with both SD and HD recordings.
What can I do ?
Thank yu, Mancio.
EDIT: added support.zip
Edited by mancio
Rename the plugins folder in the DVBViewer application folder to plugins1. Does it work?
Thanks for fast answer.
No it doesn't: now it doesn't record even other tracks. You would like to say that it's a plugin engaging problem ?
Thanks, Mancio.
..use a CI-module and a valid subscription. Then all tracks will be recorded.
I already have a valid subscription of course, are you sure that with a CI module I'll solve the problem ? With other viewers I don't have this kind of problem and I wouldn't buy a CI and a CAM only to see that I'm at the starting point.
Thank you very much, Mancio.
..well, read the rules (§ 13)
closed
