Slovak EPG problem
pemat
There is still problem with Slovak and Czech diakritics on SkyLink and Gital on 23.5E. There are same channels on UPC (19.2E) and they are ok. Its just 23.5E slovak and czech channels with wrong diacritics. It is quite annoing when all letters are messed up. Hope it can be fixed.
well since it is ok on 19.2 there must be a difference in the transmission of the epg on 23.5e. The viewer doesn't handle EPG SAT dependend :(
Something wrong is inside PRO version because GE version displays EPG without acute and wedge, but it's readable (GE.jpg). PRO version display extra character before correct character without acute/wedge and it's absolutely unreadable (PRO_DEFAULT.jpg). There is special Czech/Slovak font which allows display EPG almost correct, but it is impossible to set this font in PRO except OSD (PRO_SPECIAL_FONT.jpg). All screenshots are from the same channel with the same words…
Please allow changing EPG font in PRO or correct bug in PRO.
Thanks!
Thanks!
The problem with not correct diacritics (in Czech) was published here more times without any response from DVBViewer developers. There are more possibilities how to identify the language in the stream, I have written it in one of my topic. I am waiting for some qualified reply, because it is quite annoying.
Regards,
Zetka, Prague.
In the membersarea at the end of the page is a testversion of the viewer for ces EPG.
Just extract the dvbviewertest.exe into your current beta installation, delete your epg.dat and start the dvbviewertest.exe.
Great day today :-) At first sight it seems to work! Thanks a lot for fixing. Only one smal bug remain but who cares. (Some kind of technical info in detail window is still wrong, probably for all channels - for example the last three line in attached screenshot)
Found it, fixed it. ;) I simply forgot the component descriptions... :)
Great Christmas box :-). In Czech is everything OK, I hope in Slovak too.
There is possible download corrected version? I couldn't find it on members area page. Thanks
On slovak side is everythink showing ok now. Thanks a lot and happy new year!!! :biggrin:
