DiseqC failure.
tulipyun
I use DVBViewer 3.9.4.103RC
When I change channel at DiseqC PosA/Opt A,everything is ok.
(I use LNB1 with 138,LNB4 with 134,but i change 134 at LNB1,erveything is ok)
but at other port(like PosB/OptB),DVBViewer may lost signal,must to 'rebullid graph',could you fix it?
Edited by tulipyun
Try to change Options -> Hardware -> Stop Stream While Tuning and/or New Tuning Method/Direct Tuning. Play a bit with it - maybe it helps.
thanks your help,but it's not working.
new logs here.
