Breaker27 Posted December 14, 2008 Posted December 14, 2008 (edited) When I start DVBViewer without tuning to a channel (e.g. by the scheduler), getting FDVBViewer.DataManager.Value['#Recording.Next'] from a little helper application of mine (using the COM API) returns nothing. After channel tune, it works. It seems, that the DataManagers data is not updated in this case after startup. Fortunately, FDVBViewer.TimerManager.NextRecordingTime works properly. I use DVBViewer Pro 3.9.4.0. Edited December 14, 2008 by Breaker27 Quote
Breaker27 Posted December 15, 2008 Author Posted December 15, 2008 there is no "#Recording.Next" When I use the DVBVSpy Example Program, it shows me such an item. Quote
Lars_MQ Posted December 15, 2008 Posted December 15, 2008 maybe it is set by one of the osd-skin scripts. The viewer itself does not use such a tag. Quote
