Skaarup Posted December 15, 2008 Posted December 15, 2008 I have had a problem with <subject> for some time now. When I watch a DVB-T channel and zaps to a DVB-S channel, DVBViewer just shows a black screen. Ie. if I want to switch from one tuner to another, I have to use the function "Close graph" before I can switch. I have this problem with the Hauppauge HVR-4000 when switching from DVB-T to DVB-S and the other way around. On my previous tuner (HVR-3000) it was only a problem when switching from DVB-T to DVB-S whereas DVB-S to DVB-T was no problem. Also: since I got the HVR-4000 I have had the problem of not being able to zap from DVB-T to DVB-S using the channel + function. Let me explain: I have 5 DVB-T channels on channel numbers 0, 1, 2, 3 and 4 and DVB-S on channels 5 upwards. If I'm on channel 4 and have "closed graph" to switch to channel no. 5 it goes back to channel no. 0 when pressing channel +. Can anyone help me with these problems, please? I have DVBViewer 3.9.4 on a Windows Vista 32bit PC Regards Claus Quote
villadsen Posted December 22, 2008 Posted December 22, 2008 Hi Claus, Did version 4.0 solve the issues that you have with your HVR 4000 card? I am interested in getting such a card, but I would like to know if it works properly. Thanks Quote
peneau Posted January 11, 2009 Posted January 11, 2009 Hi Claus, Did version 4.0 solve the issues that you have with your HVR 4000 card? I am interested in getting such a card, but I would like to know if it works properly. Thanks Hi, I can't speak for the HVR-4000 card but I have the HVR-3000 and DVBViewer V4 has solved the switching between DVB-S and DVB-T problem it works like a dream now and although the HVR-3000 is not a HD based card it picks up BBC HD and ITV HD transmissions beautifully with this outstanding software. Hope that helps. Quote
