cancelling padding when recording consecutive programmes
frazer
Is it possible to set DVBViewer to automatcially cancel the padding around the recordings if you set it to record two programmes on different frequencies, the second of which starts when the first ends? Or do you have to change the padding manually for each recording- a bit less user friendly?
Thanks,
Frazer
you have to change it manually. It may be less user friendly, but it's optimized on secure recordings...
