Problem with asian characters in folder and file names
riviera
I've a problem with DVBViewer 3.9.4.0 (and latest betas) and folders/files with asian (I think It's chinese) characters in the name.
Tested in Windows XP x64 Pro (also tested on XP 32 bits).
I download NBA games and play it with DVBViewer. I go to "My Videos" section and browse to the file. When the game's folder contains Chinese characters in the name, the game file does'nt show:
Folder name and file name. OSD don't show the file within the folder
If I change folder name, now OSD show file and I can play it
If The folder name don't, but the file name yes contains asian characters, DVBViewer shows a Video/pin render error:
Rename file name, I can play game correctly.
The DVBViewer did not Support Unicode.
The Asian characters only will displayed correctly if you cage the Windows System language to this Asian language.
I´ve installed Asian languages for XP (as you seen in first capture).
The problem doesn´t this. The problem is if the folder name includes Asian characters, the contents (game file) aren´t shown (see first post). Or when is The file name which containing asian characters, appears video/pin error (see post 2).
I don't really matter if DVBViewer not display the folder/files names with these characters. The mistake is that I can´t play it.
Thanks.
Thanks.
I also have this problem. Please help to fix this problem. Thanks.
