4 different dvb cards with dvb viewer?
sadivarol
i want to buy 4 different dvb cards for my htpc
1 piece dvb-s2 Technisat SkyStar HD2 pci
3 pieces dvb-t usb stick (which one support DVBViewer)
same time , i want to see dvb-s2 and records 3 dvb-t channels.
DVBViewer software support 4 different dvb cards?
if one dvbvierw.exe can not support 4 different tuner
than i can use two or more DVBViewer.exe files.
is it possible?
do you know any ideas for 4 different types dvb cards using with DVBViewer ?
using 3 dvb-s cards (PCI, USB, Firewire): one with a USB-CAM, one with -T as hybrid and a dual DVB-T usb stick. no problems here :)
you use different type connections.
is it possible same type connections ? for example 3 usb device for dvb-t ?
and may you inform me, how did you setup 3 different cards ?
with one DVBViewer.exe or run 3 different exe files ?
small explanation enough for me.
last question
DVBViewer , which dvb-t usb sticks support ?
"dual DVB-T usb stick"
which company and model ?
may you inform me ?
i couldnot find any dual DVB-T usb stick ?
becasue i need 3 pieces dvbt tuner
if possible, i use one usb dvb stick , one dual DVB-T usb stick
totaly 3 pieces dvt tuner , plus one pci dvb-s2 hd card (for watching)
