Ac3 Audio (I have searched First!)
Milly
Found the libfaad2.dll registered the wrapper droppped the dll in filters folder and it still doesn't work for me??
HBO romania AC3 eng nothing, Canal+ Film HD AC3 works though?? seemingly i am only getting ac3 audio on hd channels but not on sd as Digigold won't work either on ac3...
The libfaad2 wrapper is supposed for AAC audio, not for AC3.
If you want a good AC3 audio decoder, get it from here:
http://ac3filter.net/projects/ac3filter
Is that the same as the one in K-lite codec pack if so i have that as the filter in there ac3=ac3filter, aac - libfaad2 wrapper
Guess i'm doing something else wrong there then otherwise there is no actual ac3 english audio carried on the channel.
Can i stream thru Videolan to see if it works?? (the audio)
