Diego Posted December 21, 2008 Posted December 21, 2008 Hello everybody, well I experimented this issue also in last DVBV 3.9.4 but video break up weren't so many. But now with last DVBV v 4 video breaks up happen more often and loaded ram increase more heavly and could be a problem. More or less viewing a h264 channel like Astra HD ram increase of 10 MB every video break up that happen. I don't know why video break up happens but at the end if ram goes to high it's a big problem. DVBV show this issue with every codec and render mode. Quote
Lars_MQ Posted December 21, 2008 Posted December 21, 2008 This is a decoder problem, most likly cyberlink, which does eat vast amounts of memory to buffer if it can not playback fast enough. So your problem seems to be is a system not able to play this. Quote
Diego Posted December 21, 2008 Author Posted December 21, 2008 (edited) DVBV show this issue with every codec and render mode. Well seems this issue afflict DVBV with divx h264 codec every render, but not cyberlink codec. I will do some more tests. And thank you for the xmast gift ^__________^ Edited December 21, 2008 by Diego Quote
Diego Posted December 24, 2008 Author Posted December 24, 2008 Did you edit latency within DVBSource? Well I didn't edit the latency but by default it was 350 ms. Yesterday I saw I had only few breaks up, but on every break up using divx h264 raw usage goes upper so the issue remain. In any way yesterday I tryed editing also the latency but well I don't really know how to edit it. I enabled clock of DVBV and then I supposed to rise latencyes to the ten upper seiing clock drift on dvbsource and instability under VMR9. But I don't know if it is correct or not. May you tell me how to edit latencyes? In any way i will report the issue also to divx, and perhaps probably the many break up were a problem of the broadcasting perhaps some bad weather near the broadcaster betadigital. But that's also true my system is at the edge of its possibility, for this reason I hope now that ati stream is ready and OpenCL is now a standard for all, in near future we would see good things from new video decoders, isn't it? Ahhh and Merry Christmas to all. Quote
Diego Posted December 24, 2008 Author Posted December 24, 2008 (edited) Did you edit latency within DVBSource? Merry Christmas to all. Edited December 24, 2008 by Diego Quote
