problems with pay-tv
guardian24
hi, i have strange problem with pay tv. I get huge amount of discontinuities in pay tv channels. Freeview channels works just fine. I have tried different renderers, different codecs etc. but nothing helps. This problem begun when i updated my computer. Before with old cpu and stuff pay tv worked. Can anyone help a bit, please.
I have got the same problem, as soon as I disconnect the CI module (Terratec USB) the problem is gone. I use the latest version of DVB, with what version did your pay tv work properly?
My DVBViewer havent been working ever. Meaning that with this computer pay tv havent worked with any version of DVBViewer. In previous computer (with same tv cardset) DVBViewer worked just fine.
The difference in your case is that my system works just fine in free view channels, it doesnt matter is CI module connected or not.
is it really true that no one can help? Hope not..
  • 1 month later...
How it can be that even admins wont help, thx for nothing..
well as you said yourself, it's a hardware problem. What do you expect us to do?
Can it be hardware problem because tv card is the same and ci is the same than before? When i updated components i also updated DVBViewer. Its hard to believe that cpu change has this kind of effect to dvb software.
It is possible that there is a driver Problem. The discontinuities mean that there are errors in the stream that DVBViewer get from the driver.
