DVBViewer 4.0 + Recording service 1.4.7 problem.
Bjur
I'm using the newest DVBViewer 4.0 with Recording service also the latest version. My problem is when I exit DVBViewer the Recording Service should be orange as active, but that doesn't happen. Have worked before the install of the latest versions. What is wrong.
I'm running Vista 32 Home Premium.
Support Tool log file is attached!
Edited by Bjur
Well you could activate it in the DVBViewer -> plugins -> Service Control (or something like this). You could have read also the readme of the service, it's written there too... :D
Argh Sorry. It's because I've uninstalled completely and configured it from scratch again, and off course there was one tiny setting that slipped.
It's working now.
I have though two more questions.
I use FFDShow to control video and audio, but if I choose FFDShow in both DirectX mpeg decoder and in PostProcessor it will not run smooth.
Should I choose default in DirectX and then choose FFDShow in PostProsesor plugin or what is the best quality?
Also in one of my channels there's AC3 as default. How do I change that?
Thanks again for your help.
