How to Turnn Off or reduce window shown TV info on DVBViewer Screen?
Reza Sadeghi
on DVBViewer in zoom mode (50% or 25% or any other) whenever we change the channel a window be appeared on the screen about 3 seconds shown TV Channel info like TV channel name or Text and Time and all other info about current TV channel.
but i want it is not be shown on the screen and wait for it to disappear to watch all TV screen.
what should i do in DVBViewer settings to disappear this skin on main screen while changing TV Channels?
Is not there any answer?
how do i remove the screen shown Channel info while changing channel.
i want it does not show at all on the screen or at least reduce the time it shown to 1 milisecond.
Well you could disable the OSD in the options...
a simple solution that DVBViewer support it.
Sorry.
i did not check settings carefully enough to find the solution.
Thank you for your simple but bright answer. :biggrin:
If you want to keep OSD and only no info so is (in my german version, think you will have same options) under Options --> EPG you can set the time for epg shown by channelchange to 0sec.
