DiseqC problem with versjon 4.0
db_no
After upgrading to versjon 4 (had versjon 3.9.4.0) i am no longer able to switch from disec input A to B.
I have a HVR-4000 TV card. I think i had this problem a long time ago, but if i remeber correct i had to replace a .DLL file but i cannot remember which file.
Thanks for all input.
If you are using SimpleA/SimpleB, replace it by PosA/OptA and PosB/OptA.
It worked. :biggrin: Could you please explain why?
What is the easyest way to change the DiseqC settings for all my channels?
Edited by db_no
DVBViewer Pro 3.9.4 mapped SimpleA to PosA/OptA and SimpleB to PosB/OptA. DVBViewer Pro 4.0 now tries to do *real* SimpleA/B with your card (required for some old switches), revealing that your settings have been wrong ever since...
Channel -> Channel Editor -> Select root entry on the left side -> Select DiSEqC -> Click Update. Affects all child entries.
Thanks for your help. I am gratefull.
