Group A,B...
themaster1
What is this "Group A,B etc.." for exactly? There is no information in the help file about it.
It's in the Scan channel window under "reception type"
Edited by themaster1
For assigning channels explicitely and manually to a device, e.g. in case of two DVB-S devices connected to two different dishes, one for receiving satellite position A, the other one for position B. Or more generally, if DVBViewer can't determine by itself which device is required for which channels... the channel editor allows to assign channels to group A...H, options -> hardware to select a set of groups for each device (the groups it is suitable for).
Alright that's a pretty good explanation thanks Griga
