Twinhan Mantis 2033 and 1.1.0.400 driver
patti
Hello, is anyone using the Twinhan Mantis 2033 DVB-C card and 1.1.0.400 driver version and actually getting picture and sound with DVBViewer? I updated my driver to this version from 1.0.3.0 that I have been using for ages and thought I would try to solve my problems with a driver update but I cannot get picture nor sound. Channel scan finds the channels but that is about it...
I am not posting a support.zip this time but I would just like to get a confirmation from other users that this driver actually works with DVBViewer 4.0. The Twinhan provided DigitalTV software version 3.4b11 works without problems with this driver so the driver and card at least work together somehow...
Edited by patti
OK, I found some explanation for my problems. Using the 1.1.0.400 driver works only, if I have Has CI unchecked for the card that has my CI+conax card (I have two 2033 cards with one CI).
So, before attaching a support.zip my next question is, has anyone got this driver and CI module to work together with DVBViewer?
Thanks
Continuing my monolog here... It seems that my CAM is not on the supported list for the driver in question. Here is the list for supported CAMs by digitalrise's Mantis driver: http://forum.digitalrise.eu/viewtopic.php?t=1104
Hopefully my monolog helps someone with the same problem :biggrin:
Edited by patti
Thanks
I have working combination of Mantis 2033 (mine is marketed as Azurewave AD-CP300 but same card) and CI-module. CAM is SmarDTV Conax v4.00e CAM Rev 1.2. Have you checked that you have setup video and audio decoders correctly? I use Cyberlink Video/SP decoder for video and for audio Cyberlink Audio Decoder with Overlay Mixer as video renderer.
Hi and thanks for your reply. Yes, I have set up video and audio decoders and they work perfectly with 1.0.3 driver. 1.1.0.400 works only if I untick "Has CI" from dvbv hardware options. It looks like I just need a new CAM. Will try the same one you have, thanks once more :)
Twinhan released a newer version. 1.1.400 01/12/2008
You should give it a try
