Saving motor settings before upgrade
vondoogle
As above, is it possible to save my motor settings before I upgrade to V4.0, and then install them again after the upgrade in case they get lost?
I have them set-up via command string at the moment?
Vondoogle
The best thing is to Backup the entire Configuration Folder (in the DVBViewer > About > Configuration Folder).
Thank you, save me a lot of work later :biggrin:
Vondoogle
