stsa Posted December 28, 2008 Posted December 28, 2008 Hi, hope this is the rigth place to get knowledge about streaming from Recording service to Popcorn. I would like to know if it's possible to get subtitles when streaming from the Recording Service to Popcorn A110 ? The Recording service work's really nice and is wonderful. Regards Stsa Quote
Lars_MQ Posted December 28, 2008 Posted December 28, 2008 Unfortunatly the popcorn hour does not support DVB Subtitles. And the recording service itself can't render and send them, because it can not show anything on screen while the popcorn hour is in playback mode. One big drawback of the popcornhour (but they're working on it) Quote
stsa Posted December 30, 2008 Author Posted December 30, 2008 Unfortunatly the popcorn hour does not support DVB Subtitles. And the recording service itself can't render and send them, because it can not show anything on screen while the popcorn hour is in playback mode. One big drawback of the popcornhour (but they're working on it) Hi, thanks for your answer, Is it possible to get subtitles if you record to a share where you from PCH can play the ts-file? Regards Stefan Quote
Lars_MQ Posted December 30, 2008 Posted December 30, 2008 Unfortunatly the popcorn hour does not support DVB Subtitles. Quote
Derrick Posted January 1, 2009 Posted January 1, 2009 Is it possible to get subtitles if you record to a share where you from PCH can play the ts-file? Regards Stefan ..if you extract the subtitles to a *.srt file in the same folder as the ts-recording, the pch will show them. Quote
stsa Posted January 1, 2009 Author Posted January 1, 2009 ..if you extract the subtitles to a *.srt file in the same folder as the ts-recording, the pch will show them. Thank's, that works fine. The name of .srt must match the name of the original ts-file. Quote
