SnoopyDog Posted October 27, 2012 Author Posted October 27, 2012 Does your plugin gets refresh rate from DVB Source ? No, it uses the DVBViewer variable "#TV.video.framerate" this works for all splitters. Because on a lot of video files I'm not using dvbsource and when refresh rate didn't change When you playback such a video, press OSD blue and select "System information". Do you see a refresh rate listed there? @Dark vader: 23.976Hz is treated as 23Hz, like all graphics card drivers do. Your Plugin can not switch to 50hz (or 60hz) when returning to LiveTV? start Bluary => switch to 23hz => stop Bluray => nothing happens. Of course, it can. Right now i can test only with nVidia and Intel - Windows 7 32 and Windows 7 64. Works w/o problems on both systems. If you have the dvbspy app, can you please check, which values are reported when you switch back from Blu-Ray to Live TV in the box "Various events" => onPlayStateChange. Which values do you see for "State"? In the plugin, you should set the values: Delay before frequency switch: 100 ms [x] Rebuild graph after frequency switch Delay after frequency switch: 0 ms Quote
Dark Vader Posted October 27, 2012 Posted October 27, 2012 I put 200ms for the Delay before frequency switch parameter and it works now (Is it the time between the beginning of the reading of the file and the switching of the display ?). @SnoopyDog : it would be a great idea if you put an explanation for each parameter on the first page of this thread (I found nothing in the wiki). Not all the drivers propose the 23Hz frequency, the ATI driver for the Radeon HD7700 (my card) doesn't propose this one (only 24, 25, 29 30, 59, 60). Fortunately it switches the display to 24Hz when I read a BD file. So for these cards could you add a parameter (something like Treat23976As24) for these cards ? Thanks in advance Quote
tomas.jurksas Posted October 27, 2012 Posted October 27, 2012 When you playback such a video, press OSD blue and select "System information". Do you see a refresh rate listed there? For H.264 video system information reports nothing in Hz. For mkv I'm using MPC Matroska Source. Quote
SnoopyDog Posted November 15, 2012 Author Posted November 15, 2012 So for these cards could you add a parameter (something like Treat23976As24) for these cards ? This is not neccessary, just assign a profile that switches to 24 Hz to the frequency value 23 Hz. For H.264 video system information reports nothing in Hz. Strange, i've never seen this. What splitter and decoder do you use for H.264/mp4? For mkv I'm using MPC Matroska Source. Unfortunatly, the MPC Matroska source filter isn't that good. The first thing is that it doesn't implement the IAMStreamSelect interface for stream switching. And i also had some problems with several .mkv files when i use this splitter. I prefer LAV Splitter for .mkv files. Quote
jasch Posted November 16, 2012 Posted November 16, 2012 Sorry i totally forgot about this thread,(since is was "dead" more then 2 months). Today will test is complete with the tweak and then report back. Thx for your work. Quote
SnoopyDog Posted November 16, 2012 Author Posted November 16, 2012 Sorry for my absence sometimes... Quote
jasch Posted November 22, 2012 Posted November 22, 2012 (edited) Ok tested 23,976;24;25;50;60 HZ All working correct with new and old switching mode for me. I´am using AMD APU and Windows 7 x64. Thx for the work. MFG Alex Edited November 22, 2012 by jasch Quote
SnoopyDog Posted November 22, 2012 Author Posted November 22, 2012 Thank you for the feedback. I'll try the next days, if it's better (or even working) to get the refresh rate directly from the filter graph right after it has been built (everything is connected already but not running). Quote
sveist Posted November 22, 2012 Posted November 22, 2012 Hi I found this neat tool and it Works great changing from 60hz to 50hz on DVBViewer startup, but i'm having problem exiting DVBViewer. I have configured "activate on Application exit" Profile 7 (=60hz) but when exiting it changes to 59hz. I'm using a nvidia gtx 660 ti and Windows 8 Pro With media center. kind regards, Svein Quote
jErk` Posted January 19, 2013 Posted January 19, 2013 Hallo SnoopyDog, ich habe gesehen, dass Du Dein Plugin aktualisiert hast und mal versucht meine altes Reclock VBS damit zu ersetzten. Dabei sind mir (ATI) zwei Probleme aufgefallen: 1. Einige alte MKV (fiese prä 2008 Files) zeigen im DVBViewer 24,999Hz und Dein Plugin schaltet dann auf 24Hz. Hier wären 25Hz richtig(er). 2. Wahrscheinlich liegts am ATI Treiber, aber bei obigem Fall (50Hz => 24Hz bei 24,999HZ) und wenn von 24Hz auf 23,9Hz geschaltet wird, bleibt das Bild nach dem Umschalten schwarz und der DVBViewer(5) reagiert nicht mehr. Außer...: Man nimmt ihn vorher aus dem Fullscreen raus. Dann funktioniert das Umschalten, das Bild läuft weiter .. usw, alles gut. Hättest Du Lust den 24,999Hz Bug zu fixen und vielleicht ein "[x] Remove fullscreen before switching" Checkböxchen einzubauen? Dann flöge ReClock endlich mal raus :-) Getestet mit: W7x64, ATI 57-irgendwas, Treiber 12.10, Cyberlink 7+AC3 Filter od. LAV+LAV Gruß, jrk Quote
SnoopyDog Posted January 20, 2013 Author Posted January 20, 2013 Hi jErk, i will change the plugin so that it rounds 24.999 Hz to 25 Hz. To the other problem: maybe you can play a bit with the delays. Try to increase the time "delay before switching". A value below 100 ms is not good. Quote
markymark Posted February 3, 2013 Posted February 3, 2013 I have another issue (hope I didnt miss any previous post on this): When I stop a video with 24fps and DVBViewer returns to live TV, it keeps the 24fps profile until I change station. Quote
feuse8 Posted April 20, 2013 Posted April 20, 2013 (edited) I have another issue (hope I didnt miss any previous post on this): When I stop a video with 24fps and DVBViewer returns to live TV, it keeps the 24fps profile until I change station. I have exactly the same problem! @edit: I assigned 50 Hz to the 25Hz profile and now it works. Great plugin! Edited April 20, 2013 by feuse8 Quote
VinoRosso Posted February 20, 2014 Posted February 20, 2014 I tried to use this plugin under Windows 8.1 and i cant create profiles. They are all empty and I dont know how to create one. Maybe im just too blind to see how to use this plugin, but i got it working under win 7 a long time ago and i think that it was quite intuitive. Does this work under windows 8.1? Any help would be appreciated ;-) Quote
SnoopyDog Posted February 21, 2014 Author Posted February 21, 2014 Yes, i am using it under Windows 8.1 without problems. What graphics card are you using? In the profile combo boxes, no frequency is listed (?) Did you try the manual frequncy override function? Quote
VinoRosso Posted February 22, 2014 Posted February 22, 2014 (edited) Yes the combo boxes are empty. Tried the manual override too, but the values do not show up in the combo boxes and the configuration textfield for the override function is empty again. Maybe im using the wrong format? Running on Intel HD4000 with - according to the Intel Driver Utility - latest driver Edit: Shouldnt there be an ini file anywhere? Nothing under DVBViewer/Plugins and nothing under ProgramData/Mr-Soft/DVBViewer Edited February 22, 2014 by VinoRosso Quote
dbraner Posted February 22, 2014 Posted February 22, 2014 (edited) Does DVBViewer account have write permission in plugin folder? As far as I remember there should be an ini file in plugin folder. Edited February 22, 2014 by dbraner Quote
SnoopyDog Posted February 22, 2014 Author Posted February 22, 2014 (edited) Yes, i store the config in "C:\ProgramData\CMUV\DVBViewer\Plugins\LCDDriver.ini" and unfortunately Windows does not add the right "Everyone" has "Full access" to all subfolders in "C:\ProgramData". Normally, only the file creator has full rights... But it is strange that you don't see any entry in these boxes... I also use the Intel HD4000 graphics. And btw., i don't use a "Rebuild Graph" after switch anymore because it has some strange effects with ReClock. But i will upload another update tomorrow because i found out that a frequeny switch WITH a rebuild graph will also confuse the HbbTV engine. I added an option that you can permit frequency switch in HbbTV mode. Edited February 22, 2014 by SnoopyDog Quote
SnoopyDog Posted March 15, 2014 Author Posted March 15, 2014 Added an update to the first page: Added source refresh rates 29 Hertz and 120 Hertz Added an eighth profile for destination frequency mapping Removed the option "Treat 23.99 Hertz as 24 Hertz". Source refresh rate is now always calculated as Trunc(freq+0.01) => 23.99 Hz will be treated as 24 Hz, 23.98 Hz and below as 23 Hz. The same for 29 Hz values. Added an option to suppress frequency switching in HbbTV mode when start playing back a video. A frequency switch with a rebuild graph will kill the HbbTV engine. Changed default values: Delay before switch: 500 ms / Rebuild graph after switch: false. With newer operating systems and hardware, a rebuild graph is not neccessary anymore. A too short delay before switching the frequency may corrupt underlaying software parts (e.g. Reclock, video renderer) Quote
VinoRosso Posted March 17, 2014 Posted March 17, 2014 (edited) Im still struggling with this tool :-) After updating the Intel HD4000 driver to the latest Version the comboboxes were filled. But at the next restart they were empty again. Updated to the latest version of Frame Rate Switcher and now the values from the manual override are shown in the comboboxes (didnt work before), but it seems they have no effect. The Framerate is not switched..... Any Ideas? It is running on a MacMini2012 but i guess thats irrelevant and it worked on win7 before. Edited March 17, 2014 by VinoRosso Quote
dbraner Posted March 18, 2014 Posted March 18, 2014 For me the plugin works on the Mac Mini (2011) with Nvidia graphics. But I do not use the built in frequency changer. I use the dc command line tool instead. http://12noon.com/?page_id=80 Quote
SnoopyDog Posted March 29, 2014 Author Posted March 29, 2014 Sorry, there was a bug filling up the new boxes. Update 29.03.2014: New comboboxes were not filled properly with values. Quote
renzz Posted April 26, 2014 Posted April 26, 2014 This is a great plugin, just what DVBViewer needs. Could I ask for an enhancement? Could we have the ability to switch framerates ONLY when changing to full screen (much the same way as MPC-HC works)? For me, it doesn't really matter about framerate when running in windowed mode, and only really needs it full screen. Cheers! Quote
SnoopyDog Posted April 26, 2014 Author Posted April 26, 2014 Hi renzz, this is a good idea Will check, if this is possible. Quote
SnoopyDog Posted April 29, 2014 Author Posted April 29, 2014 I uploaded an update with the new function that you requested Quote
renzz Posted May 2, 2014 Posted May 2, 2014 Thanks for doing this so quickly. However, I cannot get it to work - I have the new tick box checked ("Switch only if DVBViewer is running in full screen") but I start DVBViewer windowed. It doesn't switch framerate as it starts (which is good) but if I double-click the window to go full screen, it doesn't switch frame rate. It does work if I have the option in DVBViewer to start full screen ticked. However, I also have a profile to execute when DVBViewer exits to switch back to 60Hz, but that doesn't seem to be getting run either. Would it be possible to work as MPC-HC does? So start windowed - no switch. Got to full screen - switch. Exit app - switch. Thanks Quote
VinoRosso Posted May 8, 2014 Posted May 8, 2014 Im not sure if i have a problem with this plugin or with understanding the 23p/24p situation. I got a lot of mkv files with 23.976 fps, the plugin switches my monitor to 23p but the video/audio gets more async the longer i look the video. If i switch the display manually to 24p everything stay in sync. So shouldnt 23,976 fps videos switch the display to 24p? Or am i having any other problems which im not aware of? Both the same on a hd4000 and a hd5000. Quote
nuts Posted May 8, 2014 Posted May 8, 2014 23p should be the right switch for 23,976 fps sources. Anyway not to choose the right refresh rate (i.e 24p, 25p) should not result in A/V async. The Player / renderer (imho) should avoid that by repeating/dropping Frames (=> jitter). I am not sure how it's implemented in DVBViewer ... maybe cinch can tell us more about it. Have you tested 23p setting with mpc-hc/be and madVR Renderer? Tested Enable/Disable Aero VSync Option? Other directshowfilter? Quote
VinoRosso Posted May 8, 2014 Posted May 8, 2014 Just did some tests in DVBViewer, i wasnt even sure that 23p is the correct rate for 23,976 fps videos. Using ffdshow as decoder because it seems the only one which can show subtitles with hardware acceleration. Aero vsync is disabled. I guess ill have to investigate more :-) Quote
dvbrewer Posted May 8, 2014 Posted May 8, 2014 Can a standard monitor do this i.e. switch to 23.976 / 24p for blu ray? My Asus monitor lists 25 29 30 50 59 60 on its windows properties page? Quote
SnoopyDog Posted May 31, 2014 Author Posted May 31, 2014 @renzz: I uploaded an update which remembers the pending frequency switches while DVBViewer is not in full screen mode. When you switch back to full screen, the last frequency switch is done, when neccessary. @VinoRosso: If your display shows 23.976 Hz content correct when it is switched to 24Hz, then set the values for 23 Hertz and 24 Hertz in the section "Frequency to profile mapping" to the same profile and make sure that this profile switches to 24 Hertz. My system needs different frequencies for 23.976 and 24 Hertz and this has nothing to do with the monitor that i connected, it is a requirement of the graphics card in combination with the direct show system. @dvbrewer: You can switch only to the frequencies that are listed in the properties pages. Quote
renzz Posted June 1, 2014 Posted June 1, 2014 @renzz: I uploaded an update which remembers the pending frequency switches while DVBViewer is not in full screen mode. When you switch back to full screen, the last frequency switch is done, when neccessary. @VinoRosso: If your display shows 23.976 Hz content correct when it is switched to 24Hz, then set the values for 23 Hertz and 24 Hertz in the section "Frequency to profile mapping" to the same profile and make sure that this profile switches to 24 Hertz. My system needs different frequencies for 23.976 and 24 Hertz and this has nothing to do with the monitor that i connected, it is a requirement of the graphics card in combination with the direct show system. @dvbrewer: You can switch only to the frequencies that are listed in the properties pages. Thanks for the update - it's almost there I have it set to change only in full screen mode (to 50Hz) but to also switch back to 60Hz on exit. I start it windowed at 60Hz and then make it full screen and at that point it switches to 50Hz. However, if I either right-click and Exit or go back to windowed and exit, it does not switch to my Profile 2 to go back to 60Hz. Quote
SnoopyDog Posted June 1, 2014 Author Posted June 1, 2014 Ups sorry, i think the switch on exit is suppressed. I will check this later this evening. I can not switch the frequency when you leave full screen mode because i geht no event when this happens... Quote
SnoopyDog Posted June 3, 2014 Author Posted June 3, 2014 Ok, the DVBViewer generates an "OnPlayStateChange" when you switch from full screen to windowed mode. So i can switch to the "Profile on Exit" when this happens... Quote
jasch Posted June 10, 2014 Posted June 10, 2014 He i updated to the newest version, the automatic Treat2399As24 option seems to be not working, i tryd with on BD image and one MKV. He shows 23.999 but i get the 24Hz stutter. When i man. switch to 24hz it runs smooth. So it seems he is switching to 23.976 mode(23) . MFG Alex Quote
Cian Posted June 21, 2014 Posted June 21, 2014 (edited) Hi, I wonder is it possible to add a resolution setting to the profiles? I use a 720p projector, but the 50Hz profile gives me a much softer picture than when I set it manually. Strangely, the projector tells me that the res is 1080p, but the desktop seems to be the same size as 720 so must be upscaled to 1080 rather than resetting the res on the graphics card. Of course the complicating factor is that not all refresh rates work at 720p on some graphics cards. There was an add-on for ATI cards that allowed you to select profiles with hotkeys stored on the CCC. Intel does not make seem to make profiles selectable via hotkeys so that would make ot more difficult. I have recently changed to an Intel card, and it has some limitations, but was nowhere near as weak as i thought it was going to be. Other than hotkeys, I'm happier with Intel than with ATI (Less crashes for a start!). I'm not a much of a gamer, so I assume that's where ATI shine. I can imagine that this change is might be very complicated and therefore may not be possible, but if I don't ask .... Thanks, C. Edited June 21, 2014 by Cian Quote
renzz Posted August 16, 2014 Posted August 16, 2014 Ok, the DVBViewer generates an "OnPlayStateChange" when you switch from full screen to windowed mode. So i can switch to the "Profile on Exit" when this happens... Hi SnoopyDog, Did you ever release a version incorporating this? The last one in your first post is still 31st May. Cheers Quote
Catweasel70 Posted October 21, 2015 Posted October 21, 2015 Where can i find a link to the latest version of the video framerate switcher ? Quote
SnoopyDog Posted October 21, 2015 Author Posted October 21, 2015 It is in the first post, as usual Quote
SnoopyDog Posted November 12, 2015 Author Posted November 12, 2015 There is an update on the first page: Update 12.11.1015: Removed unneccessary profile definitions.You can directly assign actual frequency values to set values now. An old configuration is converted to the new settings structure. Changed system base => new structure of configuration file. Old configuration is converted. Suppressed unneccessary frequency switch when changing from video playback to audio playback and visualization is active. Changed initialization / shutdown code sequence. Some changes due to new DVBViewer version. Quote
