Video frame rate switcher
SnoopyDog
Today I installed the new version but the switch does not work for me. I have configured 50Hz for 25Hz source material but the TV stays at the initial 60Hz when playing that video. Do I need to setup anything else besides the frequency?
Thanks,
Campus
  • Replies 167
  • Created
  • Last Reply
Top Posters In This Topic
  • SnoopyDog
    34
  • popy
    15
  • udo83
    13
  • sw4y
    12
Posted Images
Hi Campus,did it work with the previous version of the plugin? I mainly removed the profile section because this is not needed anymore.
Which operating system do you use?
Edited by SnoopyDog
I am running Win7x64 and this is my first try with this plugin. How can I help debugging this problem?
Thanks
  • 3 years later...
Anyone still have an active link to this frame rate changer, using madvr at moment but having issues with it switching on subsequent channel changes after first opening DVBViewer and would like to give this a try.
Thanking anyone able to help in advance,
Edited by goldfinger21
Yea, for some reason it logged me out when clicking on link and so said was unavailable.
Unfortunately having same problem with the frame rate switcher as I was having with madvr switching. After the initial startup switch, on subsequent channel changes using iptv ts streams ithey both fail to switch between frame rates. Must be an issue with the way iptv channels report the frame rate, any help would be appreciated. Frame rates of the channels are mixture of 59.940fps, 25.00fps and 50.00fps.
Thanks esackbauer, actually got the frame switcher working now, read about that svp ffdshow filter before, may give it a try at some point.
