devishian Posted January 1, 2009 Posted January 1, 2009 Hi, I finally got my Hauppaugue WinTV HVR 4000 working. Now I was programming the different commands. I assigned one button to "Eject CD". At one touch i am able to open CD tray but as i press it again it doesn't close the tray. So I searched for a command "Close CD" but I cannot find it. Am i missing something? What sould I do to close the Cd Tray from my keyboard or my remote? Thanks a lot Quote
Devastation Posted January 1, 2009 Posted January 1, 2009 I assigned one button to "Eject CD". At one touch i am able to open CD tray but as i press it again it doesn't close the tray. AfaIk the EjectCD only opens the tray. This command doesn't close. So I searched for a command "Close CD" but I cannot find it. There is no such command avaible in DVB-V. (as far as I know) Some programms can open/close with the same button, but this sends different commands. What sould I do to close the Cd Tray from my keyboard or my remote? Anyway when the tray is open you can not change the disc with the remote. So if you are there best is closing with hand. You can solve it with event ghost (or Girder) open/close tray command. But you dont need a software for sending IR-commands? Quote
