Viewing different channels
Balle
Hi
I'm planning on setting up a local home network using DVBserver and DVBViewer on my clients.
I'm using a Firedtv S2 card.
If I run dvb server on my HTPC, do I need to run a local client on the same PC to view TV?
Can I watch one channel on my server and others on my client(s)
Hi
You could trie to point a unicast device to your server and make it prefered, as opposed to normal for the physical device.
Now when you select a channel it should run by dvbserver and other clients could tap other channels from the same transponder.
Edited by pastimer
