ramonchin Posted January 2, 2009 Posted January 2, 2009 (edited) Hi Since I got mkv subtitles working, external subtitles (filename.srt) don't show up anymore on matroska files. DVBViewer doesn't load them. Are they incompatible? I'm using EVR + ffdshow. Edited January 2, 2009 by ramonchin Quote
Griga Posted January 3, 2009 Posted January 3, 2009 Most likely due to your ffdshow or DirectVobSub configuration... Quote
ramonchin Posted January 3, 2009 Author Posted January 3, 2009 In ffdshow (subtitles configuration> Search in), I typed "." for loading subtitles on the same folder, but any success. In DirectVobsub I did the same thing...any success. Quote
ramonchin Posted January 3, 2009 Author Posted January 3, 2009 (edited) So actually, I only can view embedded subtitles on matroska files... The only way to view the .srt file is unchecking manualy "embedded subtitle" on "subtitle source" in ffdshow configuration (while playing). On the other hand, DVBViewer works fine with Divx + ffdshow+ .srt file Can anyone confirm this? Edited January 4, 2009 by ramonchin Quote
znawca76 Posted April 13, 2009 Posted April 13, 2009 Can anyone confirm this? yes, the same here - looks like a bug. Quote
