Big problem: DVBViewer hangs when exiting:(
Bjur
I have a big problem with my DVBViewer.
When I exit DVB it hangs most of the time, which means the recording service won't swich to active, unless I use taskkill and start up the service again.
This is very frustrating, since I use DVB to recording etc. and I really don't know how to fix it.
I'm using FFDShow as video decoder for both normal and h264, and I'm running the latest DVB 4.0 and recording service 1.4.7 on Vista Home Premium 32.
I have attached the support log in hope that someone can help.
Edited by Bjur
I had the same problem in v3.9.4 and I tracked it down to one of my plugins [removed], once I removed all the plugins it started closing down again.
I think [removed] had a lock on a COM port and didn't shutdown properly causing DVBViewer to hang.
I'd start by removing any plugins and then add them back in one by one to find the culprit.
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
http://www.DVBViewer.info/forum/index.php?act=boardrules
I have not any plugins installed. What else could be the problem?
Sorry, I'm out of ideas then. :( I've only experienced it with plugins.
ZITAT
§ 13
Oops. Sorry, I wasn't aware, I'm new here. I was using my valid subscription card though.
